esto existe?
alfa dijo:
A mi me mola esta, que además monta un motor de 3.0 de un Alfa 166
link: http://www.listerbell.com/
Full Spec-
Lister Bell STR chassis with full integral roll cage in 50mm CDS tubing
Suspension- Lister Bell CDS tubular wishbone set with bespoke billet alloy uprights all round
Anti roll bars- Front & rear bars fitted
Brakes- 308 x 25 ventilated discs on each corner with HiSpec 4 pot calipers & EBC pads
Dampers- Gaz Gold front coilovers, Gas Gold rear struts,
Wheels- Lister Bell 8 x 16” front & 11 x 17” rear 2 piece coffin spoke rims
Tyres- Toyo R1R tyres in 225/45/16 fronts & 275/45/17 rears
Engine- 3.0litre V6 from an Alfa 166, fully rebuilt prior to being fitted in the car (receipt available)
Engine Management- Alfa 166 ECU with FBW throttle activation
Flywheel- Alfa 2.5 litre V6 solid flywheel (balanced to the engine by Vibration Free)
Transmission- 6 speed unit from the Alfa 166 with a Q2 differential fitted
Clutch- Alfa GTA unit fitted
Exhaust- Repackable Stainless system utilising standard Alfa manifolds fitted with twin catalysts
Fuel Tank- Inboard mounted fuel cell in aluminium, 45 litre capacity
Cooling- Front mounted alloy cored radiator with twin 12” ECU controlled coolant fans
Body- Lister Bell group 4 round arch body finished in pre coloured gel finish fibreglass
Glazing- E marked front & rear screens, Lexan FMR scratch resistant shatterproof side screens
Interior- Fully carpeted & sound deadened interior with alcantara dash surround & door cards
Dash Panel- Stradale type dashboard in LHD format with alloy fascia panel
Instrumentation- Fiat speedo & tacho mated to coordinated auxilliary gauges & rocker switches
Seating- Lister Bell bespoke seats with adjutable headrests trimmed in alcantara with vinyl sides
Seat Belts- Sabelt 4 point harnesses with twist buckle release
Steering Wheel- 350mm Sabelt wheel
Interior comforts- Full air conditioning system fitted
Exterior- Full replica light set, Vitaloni Californian Mirrors, Monza style fuel cap
Extras- Rear view camera system fitted as a replacement to the interior mirror
Additional- Full rubberised underbody protection applied & rally spec mudflaps fitted F & R
Pero es que esta es espectacular. A mí no me importaría tenerla ;D
O por ejemplo, la de Corrupción en Miami que era replica de un Ferrari 365 GTB/4 Spider... Esas sí molan, porque las dimensiones, interiores, etc... son como el original.
Pero éstas hechas a base de Toyotas MR2 suelen verse ridículas (al menos las que yo he visto).
Antolfista dijo:
JOANTI dijo:
Antolfista dijo:
Una vez en Valencia hubo problema con una empresa que se dedicaba hacer réplicas, incluso había un video por ahí de todos los coches que habían hecho..
Normalmente te cobran un precio único cada vez que vas a homologar. Según quien te lo hiciera.. Entre 350€ - 600€ más o menos. Pero ya con el cambio de ley que hicieron, no creo que se pueda ni hacer, no se como andará la cosa.
Y que esta empresa la fundara un amigo mio y luego me toque ver este Post, en alfistas no tiene precio, y de quien a abierto el hilo, ole ;D ;D
Muy buen post, si señor :o
Dios jajajaja y que le paso al final? Sigue haciéndolo?
NO, Lo ultimo que supe, fue que restauraba barcos..
GERAR dijo:
Si lo consintiese la marca, que no es el caso habitualmente, que problema hay ?
Recordais, los viejunos :-), Corrupción en Miami (la serie?), pues fué denunciada por Ferrari ya que usaban una réplica inicialmente (ni se notaba), luego ya en temporadas siguientes si usaron un Testa original :-)
Se llevan haciendo desde que existen coches inalcanzables y las habituales de este tipo de Ferraris, Lambos y demás de ciertas épocas se hacían sobre el motor 2.8 de Pontiac (Firebird creo) si mal no recuerdo, que se ponía en 450 cvs, que es no es este caso.
Pues si Gerar. :)
Al final el sistema de EEUU donde prácticamente puedes hacer lo que quieras si cumples con la seguridad es muy bueno. Y cada uno con su capa hace un sayo.
Cambiando de estilo recuerdo haber visto en Mónaco una "réplica" de un Rolls Royce Silver Ghost que destacaba entre tanto supercar carísimo... porque estaba realizado sobre la base de un VW Escarabajo y sin aumentar el tamaño. Parrilla original, carrocería muy bien copiada y una tapicería de cuero impecable lo convertían en una joya de lo más exclusivo. ;D
El kit car del Stratos es una pasada Alfa. Para babear.
;D ;D ¡Tentador!
el propietario del coche es de valencia, lo mismo fue tu amigo el que tiró de sierra y masilla para hacer el apaño ;D
imagino que debe ser carisimo, lo único que permanece de serie es el motor :P
Si, pero ojo no es el Celica que indica, fijaros en los mandos del AAC ... ese motor no tiene 150 Cv ... como mucho 115.
Hay que ser cutre :-P
;D
